KomodoLabs
#1 Posted : Saturday, April 14, 2012 4:49:12 PM(UTC)
KomodoLabs
Rank: Advanced Member
Was thanked: 2 time(s) in 2 post(s)
No posts yet here, so I've decided to make one.
If you don't know what OCX Updater is yet, it's a free app. written by 10Tec that let's you update projects with old versions of an OCX that aren't CLSID compatible. As their website mentions, it's much easier to use this utility to upgrade your project with OCX Updater than using Notepad and editing several files. I've used this about 5 times on 10Tec OCX products, it's worked great every time and saved me hours of editing and headaches. It's not limited to 10Tec products either. It should work on any OCX.
So when you find that a new OCX has changed its CLSID for some reason, use this instead of Notepad!
http://10tec.com/vb6-project-references-update/
Edited by moderator Friday, May 10, 2013 6:30:29 AM(UTC)  | Reason: Not specified
