Mikl
#1 Posted : Friday, March 31, 2017 11:30:48 PM(UTC)
Mikl
Hi all,
after updating to version 6.5 i get an runtime error 13 type mismatch on following code:
Code:
Dim oGrid_Vorlage   As iGrid
Public Sub oGrid_Vorlage_erstellen()
  ' This allows us to use IntelliSense below
  Set oGrid_Vorlage = Forms![frm_Auswahl]!iGrid_Vorlage.Object
I do not get this error with version 6.0
Kind Regards,
Michael
#2 Posted : Saturday, April 1, 2017 10:13:33 AM(UTC)
Most likely, the iGrid type in the first statement comes from the iGrid 6.0. Check the project references - I think you have the iGrid lib 6.0 checked there. Remove it, and add the iGrid 6.5 lib in that dialog.
