Imran
#1 Posted : Wednesday, April 12, 2017 5:18:34 PM(UTC)
Imran
I have users that now have machines with HD displays where the OS scaling is being set to 125% to 200% depending on the machine. Since iGrid column widths are set in pixels when a machine set to 200% scaling the columns appear very skinny. How can I pull this OS setting into my Access application? How is the setting reported and how do I apply it to my existing column widths so the application appears normal to the user.
I'm assuming I would need to convert instances of this
Code:
.AddCol _
                sKey:=CStr(rs("CalendarWeekID")), _
                sHeader:=rs("ShortDescription"), _
                lWidth:=42, _
                eHeaderAlignH:=igAlignHCenter, _
                eHeaderAlignV:=igAlignVCenter
Code:
.AddCol _
                lWidth:=lScalingFactor * 42, _
Imran
#2 Posted : Wednesday, April 12, 2017 5:53:22 PM(UTC)
Imran
This is what I found
Code:
Option Compare Database
Option Explicit
Private Const LOGPIXELSX As Long = 88
Private Declare Function GetDeviceCaps Lib "gdi32.dll" ( _
ByVal hdc As Long, _
ByVal nIndex As Long) As Long
Private Declare Function GetDC Lib "user32.dll" ( _
ByVal hwnd As Long) As Long
Declare Function ReleaseDC Lib "user32.dll" ( _
ByVal hwnd As Long, _
ByVal hdc As Long) As Long
Public Function GetDpi() As Long
Dim hdcScreen As Long
Dim iDPI As Long
iDPI = -1
hdcScreen = GetDC(0)
If (hdcScreen) Then
iDPI = GetDeviceCaps(hdcScreen, LOGPIXELSX)
ReleaseDC 0, hdcScreen
GetDpi = iDPI
End Function
This seems to return 96 if the setting is 100% and then the Scaling Setting * 96 for higher levels.
For example if the scaling setting is set to 125%, this function returns 120.
I should be able to use this to determine the ScalingMultiplier that needs to be applied to all column width settings
I tested this on my desktop machine as well as a SurfacePro4 and it seemed to be consistent.
Imran
thanks 1 user thanked Imran for this useful post.
Igor/10Tec on 4/13/2017(UTC)
#3 Posted : Thursday, April 13, 2017 1:17:14 PM(UTC)
A good resource to find out more about DPI-aware applications in Windows is the following MSDN article:
Writing DPI-Aware Desktop and Win32 Applications
Pay attention to the fact that starting from Windows 8.1 applications can change their contents dynamically in a multi-monitor configuration when the monitors have different DPI values (so called "per monitor–DPI aware applications"). However, in the case of iGrid and apps hosting it, I think it will be enough to worry only about the system DPI value in the nearest few years.
