Hallo together,
i have a function that formats the grid for me.
the grid has 6 columns.
the grid is on a form that is opend with .showdialog
If i call the function for the first time the
windows is opend an the Grid is filled with data and the format is as wished, everything fine.
i close this windows and open it again.
The same grid the same function at the second time
my first row has after the .cols(0).autowidth() call the
width=1 I run this in the debugger to see if my code is wrong, the same.
in the pictures that i send you you can see i try to call the .autowidth for this cell but it gives me
always width = 1. I tested if thers is data in the col, yes it is(one of the pictures)
Can anybody help me, i tryed about 4 hours to get this fixed.
Now i tested the same code with an non modal window it works fine
But i need to use the window in modal mode.
regards Thomas
Click to View Image28 View(s)
Click to View Image31 View(s)
Click to View Image30 View(s)
Click to View Image32 View(s)
Edited by user
2017-09-07T16:22:03Z
Reason: Not specified
