2012-12-13T13:19:36Z
If we use one code block in a post, it works fine:
while (true)
  boolVar = true;
2012-12-13T13:21:12Z
Two code blocks make a post unreadable.
Code block #1:
while (true)
  boolVar = true;
Code block #2:
while (true)
  boolVar = true;
2012-12-13T13:21:50Z
The "raw" text of the previous post is the following (using the percent sign instead of square brackets):
Цитата:
Code block #1:
%code=csharp%while (true)
boolVar = true;
}%/code%
Code block #2:
boolVar = true;
}%/code%
2012-12-14T08:40:45Z
The developers of the forum engine we are using (YAF, YetAnotherForum.net ) say that it is a known issue which will be fixed in the future. To make it work now, we need to add ";-1" to the code tag like this:
code=csharp;-1
Here are two code blocks in one post written with this hotfix:
while (true)
  boolVar = true;
while (true)
  boolVar = true;
Click the Edit button to see the raw post source.
