StephleHardi
2022-05-17T16:37:08Z
Hello
I purchased and tested this program since March 21
I'm really very happy with it
I suggest one improvement which, in my opinion, are essential for a product of this quality.
The possibility of being able to draw horizontal or vertical lines to separate areas.
Of course, we have CustomDrawCellBackground at our disposal and it's very good but with limits (The line does not cover the gridline and the rectangle drawn takes up space in the cells concerned
The ideal would be to be able to draw vertical or horizontal lines such as iGrid1.GridLines.Horizontal and Vertical (Color, Thickness) but individual to be able to place them at any place
I hope I have made myself understood because my English is not very good
stephane
2022-05-19T16:33:14Z
Are we talking about cell borders? Can you post a screenshot of what you need?
StephleHardi
2022-05-20T05:49:53Z
Thank you for your prompt response
yes i was talking about borders
It is in fact only a question of inserting a border (horizontal or vertical) but without encroaching on the adjacent cells
But don't worry, the "customdrawcellbackground" method works for me too
Best regards
Stephane
StephleHardi
2022-05-20T08:17:30Z
Moreover, after reflection, it is very well thus, do not change anything.
Greg, A quick little question : How do I get the latest registered update (10.1.8) ?
Thanks
Stephane
2022-05-20T15:43:24Z
The links to the retail builds of the v10.1.8 were sent in a private email message.
And BTW, my name is Igor, not Greg 🙂
StephleHardi
2022-05-20T16:13:04Z
houps !!!!!!!!!!!
yes Igor, Sorry
StephleHardi
2022-05-21T14:58:19Z
Thanks for the link to version 10.1.8
After installation, software developed with version 10.1.0 is very easily updated by simply modifying the "References" part of the project
Thanks again because I am delighted with this program
Stephane
