#1 Posted : Thursday, December 13, 2012 1:19:36 PM(UTC)
If we use one code block in a post, it works fine:
Code:
while (true)
  boolVar = true;
Edited by user Friday, December 14, 2012 8:48:28 AM(UTC)  | Reason: Not specified
#2 Posted : Thursday, December 13, 2012 1:21:12 PM(UTC)
Two code blocks make a post unreadable.
Code block #1:
Code:
while (true)
  boolVar = true;
Code block #2:
Code:
while (true)
  boolVar = true;
#3 Posted : Thursday, December 13, 2012 1:21:50 PM(UTC)
The "raw" text of the previous post is the following (using the percent sign instead of square brackets):
Quote:
Code block #1:
%code=csharp%while (true)
boolVar = true;
}%/code%
Code block #2:
boolVar = true;
}%/code%
Edited by user Thursday, December 13, 2012 1:25:14 PM(UTC)  | Reason: Not specified
#4 Posted : Friday, December 14, 2012 8:40:45 AM(UTC)
The developers of the forum engine we are using (YAF, YetAnotherForum.net) say that it is a known issue which will be fixed in the future. To make it work now, we need to add ";-1" to the code tag like this:
code=csharp;-1
Here are two code blocks in one post written with this hotfix:
Code:
while (true)
  boolVar = true;
Code:
while (true)
  boolVar = true;
Click the Edit button to see the raw post source.
Edited by user Friday, December 14, 2012 8:43:05 AM(UTC)  | Reason: Not specified
