newuser99
#1 Posted : Monday, July 16, 2018 7:16:30 AM(UTC)
newuser99
I found an article about possibly doing this in the .NET version, but I am working in Access, and the events seem different enough where I am not sure. I am studying it, but thought I would ask, maybe someone has already figured it out, or others might be interested in the answer.
The forum article about doing it in the .NET version was: https://10tec.com/forum/...eze-columns-in-iGrid-NET
Private Sub IGrid2_VScrollBarScroll(sender As Object, e As iGScrollEventArgs) Handles IGrid2.VScrollBarValueChanged
IGrid1.VScrollBar.Value = IGrid2.VScrollBar.Value
Private Sub IGrid1_VScrollBarScroll(sender As Object, e As iGScrollEventArgs) Handles IGrid1.VScrollBarValueChanged
IGrid2.VScrollBar.Value = IGrid1.VScrollBar.Value
I am going to look in the Access code samples too, but if anyone has a hint, I'm all ears!
Edited by user Monday, July 16, 2018 7:19:50 AM(UTC)  | Reason: Not specified
newuser99
#2 Posted : Tuesday, July 17, 2018 6:21:03 PM(UTC)
newuser99
Slightly different in the ActiveX version, but this works in Access2016.
NOTE: I only have vertical scroll bars, so I don't check eBar for the correct bar, but I could
Private Sub iGrid1_ScrollBarPosChanged(ByVal eBar As Long, ByVal lValue As Long)
iGrid2.VScrollBar.Value = iGrid1.VScrollBar.Value
Exit Sub
Edited by user Tuesday, July 17, 2018 6:22:46 PM(UTC)  | Reason: Slight typo - corrected.
