Aask
#1 Posted : Wednesday, November 14, 2018 9:15:15 AM(UTC)
Aask
I have the following code:
Quote:
Private Sub UserForm_Activate()
iGrid1.ColCount = 20
iGrid1.RowCount = 20
Dim b(8, 8) As Variant
For i = 2 To 9
For j = 2 To 9
b(i - 1, j - 1) = ActiveSheet.Cells(i, j).Value
Dim DirArray As Variant
DirArray = Array(Range("a2:h9").Value)
DirArray2 = [a1:a5].Value2
iGrid1.LoadFromArray 1, 1, b, False ' Works
'iGrid1.LoadFromArray 1, 1, DirArray, False ' Fails
This is from Excel VBA. I'd like to understand why, of the last 3 lines in the subroutine, why the latter two fail and possibly what the resolution is.
#2 Posted : Thursday, November 15, 2018 11:38:47 AM(UTC)
Was thanked: 137 time(s) in 137 post(s)
Yes, really, there is a problem with the LoadFromArray function when you use it with an array returned by the Range().Value call in Excel VBA. Before doing its main work, LoadFromArray checks whether a correct array with 1 or 2 dimensions is passed to the method. This check is based on low-level API calls and the COM SafeArray type used internally by the VB runtime to work with arrays. It turned out, that this approach does not work in Excel VBA - at least, in the latest versions of Excel.
I implemented another approach to get the number of array dimensions and compiled a new interim build of iGrid with this bug fix. It has been already sent to you in a private email. Test this new build of iGrid and let us know whether it works correctly.
One comment to the following code snippet:
Code:
There is no need to wrap the Range().Value call with the Array() function. Doing so you create an array with 1 item, and this item contains a 2-dimensional array returned by Range().Value. It will be an array nested into another array. To make this code work with the LoadFromArray method in iGrid, use the following syntax:
Code:
DirArray = Range("a2:h9").Value
Aask
#3 Posted : Thursday, November 15, 2018 12:55:29 PM(UTC)
Aask
Igor,
Thanks for the response.
The code snippet is not exemplary - it is the result of various things I had been trying - but I think it does the job of explaining the issues I was having.
I could not work out whether it was the Variant data type or the By Ref that was the root cause.
Variant data type are a little problematic in the sense that, in the same scope or context, you can create two Variant arrays using alternative pathways and one is 0-based and the other is 1-based.
By Ref usually means that iGrid (the server) can change a variable in my application (the client). That is not the case with the LoadFromArray method.
It turns out that the problem was a flaw in iGrid and it was neither 0-based nor By Ref.
The new version works!
Thank you very much.
Gkir
#4 Posted : Tuesday, November 20, 2018 3:45:19 PM(UTC)
Gkir
How do I access the new version? On the download page?
#5 Posted : Tuesday, November 20, 2018 4:24:48 PM(UTC)
The fixed version of the method will be available soon in the next public update of the control. If you need it urgently, send us a letter with your registration data to check whether the latest interim build of the control is available for you for free during the paid maintenance period.
#6 Posted : Monday, November 26, 2018 4:37:02 PM(UTC)
The fixed version of the LoadFromArray method is available in iGrid ActiveX 7.0 released today.
Troy
#7 Posted : Saturday, May 4, 2019 10:33:19 PM(UTC)
Troy
I just purchased Version 7.00.0015 of ActiveX iGrid as I was having issues with loadfromarray in 6.X. Seems like there was a known bug in 6.X but was resolved in 7.X. My error wasn't necessarily the Range() issue, it just simply failed.
To test 7.X, I added two new 7.X grids, configured them with identical columns, loaded the first grid the normal way, then ran this code (from the example in the chm document):
Code:
Dim arr(1 To 10, 1 To 5) As Variant
frmMain.iGrid1.LoadIntoArray 1, 1, arr
frmMain.iGrid2.Clear
frmMain.iGrid2.LoadFromArray 1, 1, arr
I can see that iGrid1 loads correctly and all the expected data is loaded.
I thought maybe it was the dimension of the array so I tried several combinations trying to match the exact number of columns and such, but no luck. On the frmMain.iGrid2.LoadFromArray line, I get the Subscript out of range error.
What might I be doing wrong?
Troy
#8 Posted : Monday, May 6, 2019 7:44:44 AM(UTC)
Troy, can you publish here or send us a sample demonstrating this issue?
