mcs
#1 Posted : Monday, February 11, 2019 6:24:26 AM(UTC)
mcs
is the extra sample "MultiSelect DropDown Editor" also existing for igrid.net 6.0
I need drop downs where a user can select items via checkbox.
Or can i use the existing version of MultiSelect DropDown Editor also in iGrid.net 6.0 - and how?!
best regards
Marcus
#2 Posted : Monday, February 11, 2019 8:01:15 AM(UTC)
Was thanked: 131 time(s) in 131 post(s)
The iGMultiSelectDropDownEditor class from that extra sample can be used with iGrid.NET 6.0. All you need to do is to add the following implementation of the new IiGDropDownControl.SetTextRenderingHint method from iGrid v6 inside the iGMultiSelectDropDownEditor class:
Code:
Public Sub SetTextRenderingHint(textRenderingHint As Drawing.Text.TextRenderingHint) Implements IiGDropDownControl.SetTextRenderingHint
    fGridList.TextRenderingHint = textRenderingHint
Edited by user Monday, February 11, 2019 8:02:20 AM(UTC)  | Reason: Not specified
mcs
#3 Posted : Friday, February 22, 2019 5:40:43 AM(UTC)
mcs
If i do so i got 2 errors in the code.
see below
do i have to import references?
I just imported the iGMultiSelectDropDownEditor.vb
#4 Posted : Friday, February 22, 2019 7:42:18 AM(UTC)
I checked this, this works on my pc.
What error do you get when you compile you project?
mcs
#5 Posted : Sunday, February 24, 2019 11:01:07 PM(UTC)
mcs
Do i need to import any other class?
I just imported the iGMultiSelectDropDownEditor.vb and added the method you wrote me.
#6 Posted : Monday, February 25, 2019 7:12:56 AM(UTC)
No need to import something special.
And look at the error list. The compiler does not find not only SetTextRenderingHint, but also the GetDropDownControl method. Your copy of the class looks corrupted.
Can you send us the full source code for the further consideration? Before packing the solution, please, remove the bin and obj subfolders with executable contents.
Similar Topics
MultiSelect DropDown Editor for iGrid.net 6.0 from china (WinForms Grid Questions and Issues)
by hlm750908 3/5/2019 7:51:49 PM(UTC)
