Imran
#1 Posted : Wednesday, April 10, 2019 4:03:18 PM(UTC)
Imran
Rank: Member
I just upgraded to 7.0 and I'm finding that events are not triggering when the grid is referenced from a class module. For example.
On my form with the grid I have:
Code:
Dim moLayoutTool As clsLayoutTool
Set moLayoutTool = New clsLayoutTool
Set moLayoutTool.iGridColumnList = iGridColumnList.Object
Then in my class object I have:
Code:
Public WithEvents iGridColumnList As iGrid
Private Sub iGridColumnList_CellCheckChange( _
        ByVal lRow As Long, _
        ByVal lCol As Long, _
        ByRef eNewCheckState As ECellCheckState, _
        ByRef bCancel As Boolean)
But the cell check change event does not fire anymore, it used to in 6.5.
Anyone else experiencing this or have any ideas?
Thanks
Imran
Edited by moderator Thursday, April 11, 2019 11:36:53 AM(UTC)  | Reason: Igor/10Tec cleared the original post status set as 'Issue'
Imran
#2 Posted : Wednesday, April 10, 2019 4:41:17 PM(UTC)
Imran
Rank: Member
Nevermind, I see now that the Event CellCheckChange has been changed to BeforeCellCheckChange. I guess I should read release notes.
Imran
