sergiokml
#1 Posted : Monday, September 2, 2019 9:02:02 PM(UTC)
sergiokml
Hi, I've been using the class provided by you, but I run into a problem and hopefully you can help me. Every time I load the grid and add rows, the hyperlink event (CellMouseDown) fires so many times I have loaded the grid with rows. Is it possible to cancel the event so that it is triggered only once? Or would I have to instantiate the class every time I filled the grid?
#2 Posted : Wednesday, September 4, 2019 12:23:04 PM(UTC)
Can you publish here or send us a sample demonstrating the problem?
FYI: remove the bin and obj subfolders with compiled stuff before packing your project.
sergiokml
#3 Posted : Wednesday, September 4, 2019 10:36:17 PM(UTC)
sergiokml
ok
My sub:
I have 2 cols with hyperlinks:
Code:
 Private Sub HCM_CellLinkClick(ByVal sender As Object, ByVal e As HelperHyperlinkGrilla.IGHCMCellLinkClickEventArgs) Handles HCM.CellLinkClick
        Dim c As String = e.Cell.Text
        If c.StartsWith("D") Then 'Es carta
            Dim cm As DTOCuadroFacturacion = cartasHyperlinks.Find(Function(x) x.LetterCode = c)
            Process.Start($"{cm.LetterFile}")
            Exit Sub
        Process.Start($"{HelperGlobalVar.BaseUri}pagos/instrucciones/{c}")
        e.Cell.Row.Selected = True
Code:
Private Sub HCM_CellIsLink(ByVal sender As Object, ByVal e As HelperHyperlinkGrilla.iGHCMCellIsLinkEventArgs) Handles HCM.CellIsLink
        Dim c As String = CType(e.Cell.Value, String)
        If c IsNot Nothing Then
            If c.StartsWith("D") AndAlso c.Length = 7 Then 'Es carta
                e.IsLink = True
        If instruccionesHyperlink.Contains(c) Then
            e.IsLink = True
This event should shoot 1 time and not 2, 3 or plus. in both cases, my two columns wtih hyperlinks happen the same thing. (one clik= 2,3,4,etc.... browser page open) its weird but in debugger time doesn't happen.
Code:
   Private Sub FGrid_CellMouseDown(ByVal sender As Object, ByVal e As iGCellMouseDownEventArgs)
        If fPointerOverLink Then
            ' do not edit the cell if it has been already selected
            e.DoDefault = False
            ' just select the cell
            FGrid.SetCurCell(e.RowIndex, e.ColIndex)
            ' this is the place for your code that processes the link click
            RaiseEvent CellLinkClick(Me, New IGHCMCellLinkClickEventArgs(FGrid.Cells(e.RowIndex, e.ColIndex)))
Edited by user Thursday, September 5, 2019 7:45:26 PM(UTC)  | Reason: Not specified
#4 Posted : Friday, September 6, 2019 11:59:58 AM(UTC)
Is it a problem to send us a sample to reproduce the problem we can launch on our pc? We need to see the issue 'live'.
sergiokml
#5 Posted : Friday, September 6, 2019 8:51:29 PM(UTC)
sergiokml
ok. i send you the video when the event repeat.
https://drive.google.com...yHndaZx/view?usp=sharing
in mode debugger that no happen...
Edited by user Friday, September 6, 2019 8:53:07 PM(UTC)  | Reason: Not specified
#6 Posted : Monday, September 9, 2019 7:13:11 AM(UTC)
Please, understand me. I need a sample to reproduce the problem on my pc under the debugger. Can you prepare and send me one? Or can the problem be reproduced in the public extra sample?
