alex_tr
#1 Posted : Wednesday, November 20, 2019 8:07:07 PM(UTC)
alex_tr
About to buy iGrid. It is really fantastic!
Is there a way to control the highlighted fore color on a cell-by-cell (or row-by-row) basis?
I have a grid where the rows are displayed with different fore colors based on certain conditions (e.g. if an item is 'expired', row forecolor is red, etc.). When I select the rows (using row-level selection), the forecolor changes to HighlightForeColor setting regardless of what the unhighlighted forecolor was, whereas I would prefer for the forecolor to remain the same color as when it is in non-highlighted state.
Is there a way to do that?
Alex
#2 Posted : Thursday, November 21, 2019 1:52:49 PM(UTC)
Perhaps, you can implement what you need with the SelectionAlphaBlend property. It allows you to implement semi-transparent selection which will not change a lot the real foreground color of cells. try to play with the values of this property to adjust the desired effect.
Andrew Price
#3 Posted : Tuesday, December 24, 2019 11:33:57 AM(UTC)
Andrew Price
Sorry I cannot find a reference to 'SelectionAlphaBlend' in the help.
Could you explain further please?
#4 Posted : Tuesday, December 24, 2019 3:42:11 PM(UTC)
Andrew, this is a section for the ActiveX edition of iGrid. You are using iGrid for .NET, and it uses the standard .NET way to specify semi-transparent colors in the ARGB format.
