Ciaran
#1 Posted : Wednesday, November 27, 2019 2:22:54 AM(UTC)
Ciaran
Hi there
Recently I experienced the following odd behaviour with iGrid.NET (v6.0.34) in vs2017/2019 under .NET4 (and above ... yes, I have tried all combinations) on Win10.
  1. I cannot select the existing grid on a form by clicking on it. Instead I must drag a square over the control to select it.
  2. When I add iGrid to a winform it doesn't display on the form. Instead it drops to the work/component tray below.
  3. My column definitions have disappeared plus when I re-add said columns they are not saved.
I am currently running twin monitors on Win10 1903 (Build 18362.476). I suspect that this is as a result of a windows/.NET upgrade.
What are your thoughts?
Ciaran
Ciaran
#2 Posted : Wednesday, November 27, 2019 3:21:12 AM(UTC)
Ciaran
Ahhhhhhhh
Discovered this "Deploying iGrid.NET v3+ for development without installing the demo". Therein lies my salvation.
Cheers
Ciaran
