tomweber
2016-08-03T21:13:32Z
Hello!
Is there any best-pratice example for showing a tooltip on an iGrid NET component like this?
Thank you!
2016-08-17T09:07:33Z
A good idea came into my mind. Perhaps, you need to suppress the built-in cell tooltip in the RequestCellToolTipText event by setting the Text parameter to an empty string and then attach a balloon tooltip like on your picture to the whole grid in the same event handler. However, you need a separate component that implements such a balloon tooltip to use it in this scenario.
