TKG
  • TKG
2013-10-07T06:03:42Z
is there any plan to make iGrid.net touch enabled ?
or any new features for next release ?
thanks.
2013-10-07T07:12:10Z
It's a very good question. Several customers already requested the native touch support for Windows 7 and 8, but the lists of requested features are enough different. In one case it's only basic scrolling using fingers on devices like Windows 7 tablets, in other cases these are the ability to zoom the grid contents using pinch-to-zoom and to increase the thickness of its scroll bars to make them more convenient for fingers.
Can you tell us your detailed requirements for this functionality?
2014-10-03T10:44:50Z
The support of basic touch gestures was added with the release of the v4.6.5. The pertinent excerpt from the What's New :
引用:
Added support for the standard touch gestures available on touch screen in Windows 7, 8 and 8.1. The current version of iGrid.NET allows you to use the pan gesture with inertia to scroll the grid contents, and the press-and-hold gesture as an equivalent of right-click.
However, some developers suggested more features the end users of our grid control may need (consider them as ideas):
  1. Ability to enlarge scroll bars to make them more finger-friendly. Most likely, we need a new integer property in the scroll bar settings objects for that.
  2. Support for pinch and stretch to zoom. However, there are many questions related to this point: what to do with row heights and column widths, grid font, etc.
The question of further touch-related improvements is still opened, so feel free to place your comments and suggestions here.
