Bruno Montalvan
2014-01-23T21:33:51Z
I need set a calendar control to a cell, which can update the date field.
Somebody help me?
2014-01-24T07:43:48Z
The original ideology of iGrid is to be a lightweight grid control first of all, and that's why it does not have a lot of built-in cell editors like MS FlexGrid or ListView.
To implement what you need, you need to use custom editing. If you are developing in VB6, you can look at the 'Custom editing with DateTimePicker' sample in our online Extra Samples Library for iGrid:
http://10tec.com/activex-grid/extra-samples.aspx
Bruno Montalvan
2014-01-24T13:35:22Z
Imran
2021-08-30T16:00:37Z
Any tips on how to do this in Access?
