I would like to be able (in VBA) to trigger a Replace function for text in a column by right-clicking on the column header.
Is it possible to extend the built-in context menu to enable me to add in extra functions such as this?
It wasn't possible 2 years ago according to the forum, but is it now?
Alternatively, is it possible to create a custom context menu including the items that the built-in column header context menu already has (Sort Ascending, Sort Descending, Group by this Column, Remove Grouping),
plus any items that I might want to add? I wouldn't want to lose the existing functions. I would also prefer not to have to invent my own code for the existing functions when you have the code already.
Best wishes (I am enjoying iGrid),
Ian Lucas
Edited by moderator
2017-03-22T13:57:04Z
Reason: Igor/10Tec: Added implementation status to the post subject
