Hi Igor
I would like to set an iGrid control's height the way it shows all rows, i.d. there should be no need to scroll vertically.
I tried to calculate and set the control's height as follows:
ctrl.Width = PixelsToTwips(grd.Sys(igSysRowsVisScrollHeight) + (grd.Sys(igSysClientAreaHeight) _
- grd.Sys(igSysCellsAreaHeight)), gsaDirectionVertical) _
+ ctrl.TopPadding + ctrl.BottomPadding
PixelsToTwips() is a function to convert pixel values to Twips:
Public Function PixelsToTwips(lPixels As Long, lDirection As TScreenDirection) As Long
Dim lngDeviceHandle As Long
Dim lPixelsPerInch As Long
lngDeviceHandle = GetDC(0) 'API function
If lDirection = TScreenDirection.gsaDirectionHorizontal Then
lPixelsPerInch = GetDeviceCaps(lngDeviceHandle, 88) 'API function
Else
lPixelsPerInch = GetDeviceCaps(lngDeviceHandle, 90) 'API function
lngDeviceHandle = ReleaseDC(0, lngDeviceHandle) 'API function
PixelsToTwips = lPixels * 1440 / lPixelsPerInch
End Function
The result comes close but I still seem to neglect something, i.e. I still have to scroll a bit.
Do you have any hint for me?
Thanks!
Marc
PS. I'm developing with Access 2010.
