RaymondC
  • RaymondC
2015-04-17T22:57:58Z
I have a grid with 8 columns. 7 of the columns are populated with the FillFromRS method. The 8th column cannot be populated from the recordset.
I am looping through all the rows to populate the values manually but it is a little slow.
I tried using the CellDynamicText procedure but that only allows me to set a cell's TEXT and what I want to do is set the real VALUE of the cell.
What is the fastest way to do what I need?
Thank you.
Ray
2015-04-20T08:48:52Z
It seems, your post already contains a hint about the answer:
If so, then, it seems, you have no choice than to loop through all the rows and set the required cell values.
The only possible exclusion I can think of is to prepare a recordset that already contains the 8th column calculated/populated (using a stored procedure, a wider SELECT statement, etc). But I do not know whether this idea is applicable to your app.
