If it is the Modern Edition of iGrid and you are using it in Microsoft Access, then yes - it is a problem that has been recently found and we already have a fix for it.
Send us an email with a detailed description of your problem and some accompanying screenshots. We want to be sure that it is the same problem, and if so, we'll send you the links to the fixed build of iGrid.
