eric au
2012-07-12T10:26:13Z
Is there a merge cell function for iGrid. In MSFlexGrid, there is a CellMerge property which will merge the neighbor cells when they are in the same value.
2012-07-12T11:13:02Z
In iGrid, you can only merge cells in the form of row text cells.
There is no way to merge an arbitrary set of cells like you can do that in FlexGrid.
eric au
2012-07-12T12:10:53Z
Thanks for your reply.
By row text cells, do you mean text spanning across several columns?
2012-07-13T04:26:09Z
Yes - within the same row.
Like message preview in the message list in MS Outlook.
eric au
2012-07-13T10:27:19Z
Do you think my said function of merge cell can be a feature of iGrid?
With this feature, the grid looks much cleaner for rows showing repeating values with only the first row shows while the others are blank.
2012-07-14T04:52:00Z
Yes, I agree, but this feature has been never planned for iGrid.
We use "standard" group rows for this purpose.
eric au
2012-07-14T17:23:27Z
Ok, ic. Thanks a lot!
