I am trying to replace the common TreeView Control with your ActiveX control.
Building up the data for the treeview is really easy, but formating the grid
is not that easy as I need different column width for the different tree levels.
Finding a column layout that "one size fit them all" is difficult, it would
get a lot easier if we could specify igTextOverflow as ETextFormatFlag,
meaning that the text will overflow in the next adjacent cells, if they are empty.
Best regards
Klaus
