RaymondC
  • RaymondC
2013-10-24T20:43:11Z
I have an Access 2010 form that will be used on a touch monitor. Is it possible to make the scroll bars larger so they are easier to press with a finger?
2013-10-25T06:35:40Z
iGrid ActiveX uses the system settings, so the only way to do that is to configure this option through the Control Panel.
RaymondC
  • RaymondC
2013-10-25T20:16:48Z
That will work. Thank you.
