MikeF
  • MikeF
2016-01-15T14:35:48Z
I have a iGrid with a very long text. The text is longer than a line that's way I set the cell ETextFormat property to igTextWordBreak.
Now my text is readable but I cant scroll to the last line because I don't get a scrollbar.
In editing mode igTextWordBreak dos not work at all. If you write a text longer den the width of the cell I don't jump in the next line like in word.
I will be happy if anyone can tell me how to set the scroll in cell property and implement the word wrap in edit mode.
Thanks!
Gretes Mike
2016-01-16T07:06:08Z
The igTextBoxVScrollBar and igTextBoxHScrollBar flags specified in the CellTypeFlags property should enable the corresponding scroll bars in the text box editor.
If it does not help, send us a sample that demonstrate your needs.
