Sorry to be a broken record, but I've been doing some "destructive testing" of iGrid so that I know what I can and can't do with it.
Today I put in 6 text fields of a page or so long and performed a range of operations on them, mostly filtering and unfiltering according to text contained in the fields. After a few iterations of this I got an "out of stack space" message, Word crashed and will no longer let me access my code, so I have to go back to a backup I saved several hours ago :(
Not backing up often enough is "my bad". But I do need to know how well iGrid (working in conjunction with Word, ADO and Excel) handles large text fields. For the app I am developing, it is possible that there will be several hundred pieces of text of varying length, mostly fairly short but occasionally up to a page or so, with a bunch of additional data fields so that the text can be sorted according to a range of criteria selected by the user.
Are you able to advise me on this?
Also, do you have any suggestions for me (as a newbie, although an old one) as to what (if anything) I can do to reduce the chance of "out of stack space" crashes happening again?
Thanks again,
Ian
