abraXus
  • abraXus
2020-10-27T16:05:00Z
Is there a way to put a large image into a cell? The image would not need to be re-used in more than one cell.
The only way I see is to use an ImageList which has a size limit of 256x256.
I have several large bitmaps that I would like to put into cells to create a "Report" (the images are of collected data) because of the benefits the iGrid would give me for alignment, and then be able to print the resulting iGrid.
In addition, I would love it if the cells would autosize to the image contents and be able to use SpanRows and SpanCols in combination with all of this.
I already have all the bitmap objects as variables in code, I am just looking for a way to get them into a specific cell. Seems like this would be simple, but I have gone over the documentation and have not been able to find anything.
i think I have my answer. It looks like the only option is:
Цитата:
5.9. Custom Draw Cells
iGrid allows you to create custom draw cells. The custom drawing means that you can draw by
yourself a cell's background or foreground or both cell parts. Normally you draw your own contents
with GDI+.
Please advise if there is an alternative.
UPDATE:
I was able to get this to work nicely, but ran into one problem. I used the code snippet from the documentation that works fine, but I am trying to utilize it with SpanCols being set to 2 or 3 and it seems to be ignoring that setting.
Could you please point me in the right direction?
2020-10-28T11:57:06Z
Yes, custom drawing is the only way to implement what you need.
If you found an issue with custom drawing in merged cells, send us a sample project demonstrating this issue. Before packing it to zip, remove the .vs, bin and obj subfolders.
