Tommyworker
2021-04-13T13:40:09Z
i use the igDropDownList class (very helpful) in my program i have the following issue. I able to doubleclick on a selected DropDownList item. After this the text in the igDDL change in a editmode.
After this every mouseaction or Keystroke trows an error (ESC) key is the only one that helps. How can i protect the igDDL Items that they can not change in the mode?
regards Thomas
29
Click to View Image
2021-04-14T05:14:47Z
Here is the answer from the manual:
iGrid1.Cols[0].CellStyle.TypeFlags = iGCellTypeFlags.NoTextEdit;
Just specify the NoTextEdit flag for your cells with the drop-down list.
Tommyworker
2021-04-17T12:11:09Z
Hello Igor, thank you perfect. A question why must i set this manuel?
For me, if i use a dropdownlist i want to give the user a selection. The source of the dropdown is in my way a database table.
I will find it helpful when the TypeFlags, if an DropdownList is set to the col, it will automatic set the Typflag to noTextEdit?
Regards from munich,
Thomas
2021-04-19T05:37:21Z
First, it works exactly like the WinForms ComboBox control with default settings. If you drop it onto a form, its DropDownStyle is set to 'DropDown' allowing you to enter arbitrary text or select it from the list. If you want only to select from a list, you must change DropDownStyle to 'DropDownList'.
Second, look at this from the point of view of 'adding features to existing ones'. If you have a text cell and adds a drop-down list, you ADD something to the existing functionality and this should not disable anything you had earlier. In other words, what you already have - including text editing - must work after adding a drop-down list until you disable this explicitly.
