Ian Lucas
2021-08-05T04:51:18Z
I am using iGrid version 5 (build 0086) inside Word VBA.
I have created and populated an igrid table from an array of values contained in a text file, using your iGrid_From_Array routine (thank you).
I want to be add combo list to each of the cells in one of the columns, giving the user the option of selecting "ok", "fix" or "ignore".
Can I do that? I can't figure it out from the documentation.
Apologies if this is a dumb question. I'm not a professional programmer and I haven't used iGrid for a few years.
Best wishes
Ian Lucas
2021-08-05T10:49:43Z
Simply change the type of the cells to combo with the CellType property and assign the key of the combo list like you would normally create combo box cells.
BTW, the latest iGrid allows you to do this easily and effectively with the SetColCellsProp() method.
