MarcDV
2021-09-02T09:07:46Z
Bonjour,
J'aimerai par programmation me positionner sur une ligne en fonction d'une valeur (string) à trouver dans une colonne.
Pouvez-vous me proposer une solution.
Dois-je passer par l'iGrid ou l(iGAutoFilterManager.
Merci pour votre aide !
2021-09-02T14:09:51Z
Sorry, we do not understand French and Google Translator also did not help to understand your question.
Can you repost your question in English?
It would be nice too to see some accompanying screenshots if possible.
MarcDV
2021-09-06T07:13:36Z
Sorry for not being clear ;-)
I would like the programming code to realize the equivalent of the search in the text field.
Thanks
Click to View Image67 View(s)
2021-09-06T14:41:01Z
Have you seen the Custom Search-as-Type sample in the main demo (in the Ideas for Your Apps sample group)? Is it what you need?
MarcDV
2021-09-07T05:58:52Z
Yes it is perfect. I'm trying this.
I had not seen this example.
Thank you !
