YsTx
  • YsTx
2022-02-03T16:32:41Z
10Tec_iGrid.NET_X_Manual.pdf (2020)
p.11/158 :::
3. MANAGING COLUMNS
3.1. Creating and Removing Columns :::
Example 1 :::
iGrid1.Cols.Count = 1;
iGCol column = iGrid1.Cols[0];
//VS2022 says : 'iGCol' could not be found
So I'm not sure what to think regarding iGCol now ?
Thanks for reading.
Y.G. Dries / Belgium
2022-02-03T17:16:13Z
iGCol is a type from the iGrid library. It is located in the TenTec.Windows.iGridLib namespace. All samples in the manual imply that this namespace is imported at the beginning of the module:
using TenTec.Windows.iGridLib;
Otherwise we would need to write long statements like this:
TenTec.Windows.iGridLib.iGCol column = iGrid1.Cols[0];
But I agree with you that it may not be clear for a developer starting to work with iGrid. Do you think we need a preface in the manual describing this? What else should be mentioned in the preface?
TIA for your suggestions! Feedback like yours helps to improve the documentation with every realease.
