StephleHardi
2022-03-27T06:50:36Z
I have a grid with several columns and I would like to sort only the data of column #3 by clicking in its header but without sorting the other columns.
Is it possible ?
Thanks very much
2022-03-28T15:24:05Z
iGrid does not have a built-in tool for that. I think you need to process the ColHdrClick event. Disable the built-in sort in the event handler by setting e.DoDefault to False, export the column cell values into an array, sort it, and upload back into the column. Something like that.
StephleHardi
2022-03-28T16:32:45Z
It's a pity that this function is not implemented but your solution suits me well.
Thanks very much
Here is my code (VB) according to your advice and it works very well
Private Sub GL_ColHdrClick(sender As Object, e As iGColHdrClickEventArgs) Handles GL.ColHdrClick
e.DoDefault = False
Static Ascending As Boolean
Dim Mg As String, CPT, i As Integer
With GL
Dim MyArray(.Rows.Count - 1) As String
For i = 0 To .Rows.Count - 1
Mg = .CellValues(i, e.ColIndex) : If Ztrim(Mg) <> "" Then MyArray(i) = Mg
Array.Sort(MyArray) : If Ascending = False Then Array.Reverse(MyArray) 'Ascending or descending
Ascending = Not Ascending
For i = 0 To MyArray.Count - 1
If MyArray(i) <> "" Then .CellValues(CPT, e.ColIndex) = MyArray(i) : CPT += 1 ' CPT to Avoid blank lines
