I am getting an error ;-
Failed to create component 'iGrid' - 'System.Runtime,InteropService.COMException (0x804D745)'
A reference to the component 'TenTec.Windows.iGridLib.iGrid.v4.6' already exists in the project.
This error occurs when ever I try to place an iGrid control onto a form.
I removed the form on which I first noticed the problem, but that had no useful effect.
I have completely remove the reference to 'C:\10Tec\iGrid.NET 4.6\Bin\TenTec.Windows.iGridLib.iGrid.v4.6.dll' from the project and even uninstalled and reinstalled the iGrid demo and then the retail version.
The problem first started when the 'iGrid' icon disappeared from the toolbox. By trying to fix that I seem to have made things worse.
I know that it is something to do with my existing application as I can start a new solutions add the references and that works Ok.
I am using iGrid.NET version 4.6.5.0 and my application is being developed on
Visual Studios Professional 2013 Version 12.0.21005 REL.
.NET Framework version 4.5.50938
And I am using C# to do the coding.
So I have messed up somewhere but I can't find where.
So could you give me a step by step instructions for installing iGrid.NET please or is there a simpler solution. Or point me to where I can find that information please.
I have searched in the forum before creating this post
Thank you and sorry for the bother
Edited by moderator
2021-08-20T07:01:56Z
Reason: Igor/10Tec changed description
