Bruno Montalvan
2014-09-08T15:16:38Z
Hi
I need to change the cell value of a column with added combo, but when a use this code:
With iGrid
.BeginUpdate
.CellValue(.curRow, "Column01") = varChangeValue
.EndUpdate
....The cell is blank and don't show the changed value.
2014-09-09T15:06:58Z
The cell text should change and display the corresponding combo item's text if it exists.
Can you send us a sample that demonstrates the issue?
Bruno Montalvan
2014-09-16T13:25:54Z
The text that I want to show exist in the combo items and the combo items are loaded from a recordset.
2014-09-17T13:35:18Z
Filling the combo from a recordset? Then read carefully the following thread in our KB, especially post #4:
http://10tec.com/Forum/y...ing-with-FillFromRS.aspx
