enveetee
2014-11-05T10:27:10Z
Hi
I am having issues with ResizeColToFillSpace
I have 20 columns which the user can hide / reorder at will. Sometimes the last column is not visible
How should I implement ResizeColToFillSpace? Do I have to find the last visible column like this:
Dim Cols&
For Cols = iGrid1.ColCount To 1 Step -1
   If iGrid1.ColVisible(Cols) = True Then
      iGrid1.ResizeColToFillSpace (Cols)
      Exit For
Next Cols
'Im a running this code everytime the user:
Resizes grid
Reorders columns
Changes column widths
Changing the visiblity of columns
..or is there a better way
2014-11-05T11:29:35Z
You deinitely need to find the last visible column by yourself as the ResizeColToFillSpace method requires the index of a column, but in the general case this is not the last visible column.
Perhaps, you can get the last visible column using less code using an expression like this:
iGrid1.Sys(igSysColsLastVisCol)
