Elwin
  • Elwin
2022-06-28T13:46:36Z
I build a excel file with forms and Activex component IGrid. But when end users use my excel they get the missing reference of Igrid. I tried to load the .OCX on their local machine then but still the message comes to the end user that “The object cannot be loaded because it is not available on this machine” therefore misses the reference again. Is there a possibility to embed the component in the Excel file so it will always been delivered with the reference or do I need transfer other files??
2022-06-28T16:23:30Z
You must redistribute and register the iGrid OCX file with your solution. This is a part of the ActiveX technology, and you must do this for any used ActiveX control.
Read the following topics on our forum. They will help you with the registration process:
https://10tec.com/forum/...-in-the-Windows-registry
https://10tec.com/forum/...rid-without-admin-rights
