MohamedHamada
2023-04-01T03:18:21Z
How i creat a command button in first column of Excel iGrid Anyone help please
2023-04-03T13:59:29Z
There is no property or easy 'switch' for that. In VB6, we can do this using custom drawing. Look at the Command Button Cells demo here:
https://10tec.com/activex-grid/extra-samples.aspx
But I doubt this will work in Excel UserForms the same way smoothly like in VB6. Perhaps, you will have flickering or other 'side effects' related to the nature of VBA forms.
MohamedHamada
2024-03-23T03:43:54Z
I can’t find the code
Can you write here the code please
2024-03-25T07:49:32Z
There is the Download graphical button below the sample description.
