Hello
I am using iGrid 6.50.0068
I have a grid with 30 columns of which 20 are visible on the screen.
I set the iGrid.Browseallnonfrozencols = true
I set iGrid.Frozencols = 1
I set iGrid.FrozenColsEdgeWidth = 3
I set iGrid.header.usexpstyles = false
** New information. This only happens if Column 2 is not visible (iGrid.colVisible(2) = false
It appears that when I scroll the grid to the right, column 3 gets hidden behind column 1.
When I build the grid I can see all columns (except for column 3 which is hidden).
Using the keyboard I key right across the grid and Column 1 stays frozen.
When I key left back to towards columns 1, the grid uncovers up to column 3.
When I key left from column 4, the cell highlight disappears (column 3 is not visible).
On the next key left, column 1 is highlighted (still no column 3).
If I right key out of column 1, the highlight disappears (to the invisible column 3) and on the next key right, column 4 is highlighted.
If I move the scroll bar to the left, column 3 reappears and I can key into and out of it until I scroll again.
If I key right to the last column and key right to wrap around, Column 1 is highlighted with the second column being column 10.
When I key right out of column 1 column 3 is moved to the second column space and the highlighted cell disappears to the invisible column 3).
Thank you
Laurie Borlase
Edited by user
8 years ago
Reason: More information
