Tommyworker
2015-02-27T12:21:52Z
Hallo togehter,
to use the uiStrings in the Igrid i declared every string as a constant.
After this i set every const to its corosponding property in the uistrings.
(in the Form load)
The result is that the loading of the ist very slow?
Whats my fault?
VB.Net VS2010 Grid 4.6
Regard Thomas
2015-02-27T13:25:23Z
The performance of the control should not be affected. You just change some strings in memory that are used in different parts of the interface.
Can you send us a sample we can launch to see the problem?
