Carsten Knappert
2015-11-17T11:37:49Z
is it possible to find out which button was pressed by the user when he close Filterbox (OK, Cancel or ESC) ?
2015-11-17T14:41:04Z
Why do you need to know this?
If you need to know whether the user has applied a filter, you can use the FilterApplied event for that.
Carsten Knappert
2015-11-30T13:25:24Z
sorry for my late reply.
I just use the FilterApplied Event.
Reason to know last keypressed botton to close filterbox:
Private Sub igAfm_FilterApplied(...) Handles igAfm.FilterApplied
based on filtered rows - do some complex refresh operations on other parts of the form
--> user press OK to close the filterbox -> complex refresh operations
--> user press Cancel to close the filterbox -> no need to start complex refresh operations
2015-11-30T15:14:12Z
FilterApplied is triggered when OK or Apply are pressed, but not for the Cancel button. So, it seems, it is what you need.
Carsten Knappert
2015-11-30T15:36:14Z
Thanks for your answer, it works.
