I'd like to request the option to have the ability to handle the user editing a cell and then clicking on the ellipsis button without triggering the AfterCommitEdit event.
In my use case the user is entering a code from another table. The ellipsis button is there to show the list of valid values to the user. Because there can be a large number of values, a drop down isn't a good choice. I'd like to allow the user to enter in a partial match and then click the button to show the valid list of values. Then the user can select a valid choice from the list which is pushed into the cell being edited.
It allows me to validate the input in the AfterCommitEdit event.
Currently, if the user is editing the cell and clicks the button, the AfterCommitEdit event is fired and I don't have a way to determine why the ACE event was invoked.
Maybe an event called CellEditingEllipsisButtonClick?
Or, if I'm not using the existing events correctly, I'm open to changing my code around.
