Thank you for your answer.
You are right.
I could define my custom menu with the same commands as the built-in menu and create the suitable code. But as I am a bit lazy, it would have been easier to use directly the built-in menu...
Unfortunately I see it is not possible to interact with it when an item is clicked (for built-in commands).
It's a pity!
Never mind, this Grid remains probably the best ActiveX grid for VB6.
But if you have any advice, I'm more than interrested!
