naji
  • naji
2016-10-11T11:06:20Z
hello,
how i can add checkbox to header column for select all/unselect all ?
2016-10-11T13:48:33Z
I think you wanted to write "add checkbox to a column header" or "insert checkbox into a column header". Unfortunately, iGrid column headers can't contain this kind of controls. As an alternative solution I can suggest that you create a frozen row with checkboxes in its cells to implement the requested functionality.
