Hi All,
I am looking for an alternative to ComponentOne FlexGrid due to issues moving from windows 7 to 10/11 (the combo list dropdown becomes incredibly slow)
Anyway, iGrid was suggested and it looks great so far (I am using the demo)
We use the grid as a order entry system using a stock code. We have around 25,000 lines which the customer can order.
Using FillFromRS it takes about 6 seconds to process the ADO recordset (MSSQL backend) which is not bad at all.
However, the stock items dropdown combo is used in many places in the program, entering an order, stock control, setting special prices, etc.
Each of these is a different form and therefor a different iGrid.
With ComponentOne you an use BuildComboList and assign the output to a public string and then assign it to any combolist as the form is loading.
Is there anyway to do something similar with iGrid?
i.e. store the output of FillFromRS and then assign it to any new iGrid combo when the new form loads?
(or maybe some form of combocopy from a hidden master)
While the 6 second "initialisation" delay is fine on program startup its too long for every form load.
Mike
