CatFelix
2017-08-04T08:22:47Z
Why won't the following code color my col header cells. As the following Debug output indicates, the
.iGrid1.ColHeaderBackColor(i) = 15132391 and .iGrid1.ColHeaderBackColor(i) = 11389944
statements seem to set the right values, but when the grid is shown, the header cells aren't coloured.
However the
.iGrid1.ColHeaderText(i) = "AAAA"
statement does update the header text and this is shown on the grid
Sub expenseEntry()
    Dim colHeader As Object
    Dim gridWidth, i As Long
    With uExpEntryDlg
        .acTypeCB.AddItem ("Expense")
        .acTypeCB.AddItem ("Income")
        .acTypeCB.AddItem ("Cap Movt")
        .acTypeCB.AddItem ("ExtraOrdinary Expense")
        .acTypeCB.AddItem ("Miscx")
        .acTypeCB.AddItem ("XXXXX")
        .acTypeCB.ListIndex = 0
        fillCol
        Set colHeader = .iGrid1.AddCol(lWidth:=36, sHeader:="A/C#")
        fillCol
        Set colHeader = .iGrid1.AddCol(lWidth:=144, sHeader:="A/C Name")
        fillCol
        Set colHeader = .iGrid1.AddCol(lWidth:=360, sHeader:="Transaction Description")
        fillCol
        Set colHeader = .iGrid1.AddCol(lWidth:=72, sHeader:="Trans Date")
        fillCol
        Set colHeader = .iGrid1.AddCol(lWidth:=118, sHeader:="Amount")
        fillCol
        Set colHeader = .iGrid1.AddCol(lWidth:=18, sHeader:="Tax")
        fillCol
        Set colHeader = .iGrid1.AddCol(lWidth:=118, sHeader:="Project")
        fillCol
        For i = 1 To 11
            If i Mod 2 = 1 Then
                addUnselectableRow (i)
            Else
                .iGrid1.AddRow lHeight:=18
        Next i
        colorActiveCells
'        .iGrid1.Header.BackColor = g_MidOrangeColor
        'Colour Col Header Cells
        For i = 1 To 5
            If i Mod 2 = 1 Then
                .iGrid1.ColHeaderBackColor(i) = 15132391     'g_PaleGrayColor
            Else
                .iGrid1.ColHeaderBackColor(i) = 11389944     'g_MidOrangeColor
            Debug.Print i & "     " & .iGrid1.ColHeaderText(i) & "     " & .iGrid1.ColHeaderBackColor(i)
        Next i
        'Adjust Grid width = Sum (col widths)
        getScreenInfo
        gridWidth = 890 + 4 '4 for left and right grid boundaries [= 4+36+144+360+72+118+18+118+[8*unselectableColWidth] = 870+8*uscw
        .iGrid1.width = gridWidth / mptCurrentDPI.X * 72  'points = pixels/(pixels/In)*72 points per Inch
        .Show
Sub fillCol()
    With uExpEntryDlg.iGrid1.AddCol(lWidth:=3)
        .bSelectable = False
        .oBackColor = g_PaleGrayColor
Sub addUnselectableRow(r)
    Dim cRow, cCol As Long
    uExpEntryDlg.iGrid1.AddRow lHeight:=3
    For c = 1 To 15
        uExpEntryDlg.iGrid1.CellSelectable(r, c) = False
        uExpEntryDlg.iGrid1.CellBackColor(r, c) = g_PaleGrayColor
     Next c
Sub colorActiveCells()
    Dim r, c As Long
    For r = 2 To uExpEntryDlg.iGrid1.RowCount Step 2
        For c = 2 To uExpEntryDlg.iGrid1.ColCount Step 2
            uExpEntryDlg.iGrid1.CellBackColor(r, c) = g_PaleYellowColor
        Next c
    Next r
Quote:
1 15132391
2 AAAA 11389944
3 15132391
4 AAAA 11389944
5 15132391
An Image of the output grid is attached
  screen.docx (36kb) downloaded 253 time(s).
2017-08-04T11:09:32Z
By default, the OS visual styles are use to draw the iGrid column header. If so, the column header background comes from the OS and there is no chance to apply our custom color formatting.
To make it work, simply disable visual styles in the iGrid header using the following statement:
iGrid1.Header.UseXPStyles = False
