Jirka
  • Jirka
2017-08-17T23:01:18Z
Is it possible use any systematic aproach to put some data (for example sums) into group row on fitting possitions aligned with other columns? Main goal is use grouping and show some for example subtotals from collapsed groups in group row but formated almost like in normal row.
Thanks for possible ideas.
2017-08-30T13:21:32Z
A fresh idea: what about using a tree grid for that?
As for group rows, you could use custom drawing - though it would be a tedious work if you went this way.
