I'm using iGrid.Net in Labview and sometimes I get an unhandled exception error message directly (exception that is not catched by Labview as it usually do with .NET exceptions).
In this project I use iGrid.Net only writing data into cells, changing the color of the cells and reading selected cells for other purposes, so nothing so complicated, but I get this exception in a part of the code where I don't call any iGrid.Net related method nor property, so it is really hard to understand what's wrong.
iGrid.NET is the only .NET code in this project, but in this same project there is implemented also igrid ActiveX 3.00 (I don't know if it can cause some issues but I don't think).
I attached the screenshot of the error message and the details taken from that window. Does anyone knows what should be the problem?
(Sorry for italian messages, but I'm Italian and I'm using an italian localized Windows 10)
Thank you
Click to View Image161 View(s)
Exception details.txt
(6kb) downloaded 151 time(s).
