raffeo
2018-03-05T17:41:18Z
Click to View Image257 View(s)
I need help because I have a problem with font on Igrid.
In attachment a custom datagridview (up) and a Igrid (down) with same data and same font. On Igrid data cannot be read clearly.
Have you any idea of the problem?
It's the same if I change font.
Thanks
2018-03-06T07:36:27Z
If you meant the ability to set the anti-alias mode for texts iniGrid, now this can be done with the TextRenderingHint property introduced in iGrid.NET 6.0.
raffeo
2018-03-06T08:54:23Z
I mean that character in igrid seem to be out of focus.
In attached image I have a datagridview and a igrid with same data and same format but in igrid data are out of focus.
Do I need to set a property on grid or is a problem?
Thanks
2018-03-08T18:02:15Z
Perhaps, I do not understand. Do you mean the blurriness of characters? If so, try to play with the TextRenderingHint property in the latest version of iGrid.NET and tell us whether one of the values it can accept solves the problem.
