Silent D Software
2018-04-02T16:33:31Z
Does iGrid give us the possibility to set cell borders? For example I would like to make the border between two columns 2 or 3 points wide.
2018-04-03T11:27:21Z
iGrid cells do not have properties to control their borders. You need to use custom drawing to implement what you need. I think the most appropriate events for that are BeforeCellContentsDraw/AfterCellContentsDraw, which are generally used to add some extra graphical elements to the standard cell contents.
LucaAsca
2018-07-16T23:21:33Z
Any idea which WinAPI function one could use to draw borders?
Dmitry/10Tec
2018-07-17T10:38:57Z
https://stackoverflow.co...of-the-listview/41965020  for example.
