Portman
2012-06-08T09:22:38Z
I noticed that the ECellType=igCellCheck is no longer available in version 5.0.
To render this type of cell, for all the column, in previous version i used:
LV.ColDefaultCell(0).eType = igCellCheck
now i receive the error:
'invalide procedure call or argument'
Is there an easy way to do the same thing in the new version?
TY
Fabrizio
2012-06-08T09:39:13Z
iGrid 5.0 is supplied with a comprehensive list of changes - read the '10Tec iGrid ActiveX 5.0 - What's New in Release' PDF. You can find it in the demo installation or online on our website:
http://www.10tec.com/FS/Products_doc/10Tec_iGrid_ActiveX_5.0_Whats_New_in_Release.pdf
The document contains a guide which will help you to upgrade your code from the v4 to v5, including the new cell check box system.
In a nutshell, now any cell can display the check box [in addition to the standard contents such as text and icons - if you need that]. You can turn this on for a particular cell using the new Boolean CellCheckVisible property. Other properties, such as CellCheckPos and CellCheckState, are used to specify the check box position and read/set its state.
Portman
2012-06-08T11:29:47Z
TY it's even easier!
